Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
Product Description | Kensington SD4700P USB-C and USB 3.0 Dock - docking station - USB-C / USB 3.0 - HDMI, DP - 1GbE | Product Type | Docking station | Docking Interface | USB-C / USB 3.0 | Video Interfaces | HDMI, DP | Dimensions (WxDxH) | 20 cm x 9.12 cm x 3.05 cm | Weight | 1.13 kg | Colour | Black | Localisation | Europe | Networking | Gigabit Ethernet | Power | Power adapter AC 120/230 V / DC 20 V (50/60 Hz) 135 Watt Power Provided | Pricing Type | Brown Box | Manufacturer Warranty | 3-year warranty |
General | |
Width | 20 cm |
Depth | 9.12 cm |
Height | 3.05 cm |
Weight | 1.13 kg |
Enclosure Colour | Black |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB-C cable - external - 1 m , 1 x USB-C to USB 3.0 adapter - external |
Features | Security lock slot (cable lock sold separately), VESA interface support, 1 USB 3.0 fast charging port, Zero Footprint Mounting |
Security Slot Type | Kensington security slot |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE, REACH, RCM |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V / DC 20 V (50/60 Hz) |
Power Provided | 135 Watt |
System Requirements | |
OS Required | Microsoft Windows 7 / 10, Apple macOS 10.13 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
