Kingston 8GB DDR4 2666MHz ECC Memory
£51.38
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Memory module
  • Registered DDR4
  • 2666 MHz
  • ECC
  • Single rank
  • DIMM 288-pin form factor
  • Type: DDR4 SDRAM
  • Capacity: 8GB
  • Connection: DIMM 288-pin
  • Speed: 2666MHz
  • Data Integrity: ECC
Product codes
Kingston DDR4 8 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC
Product Description Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Product Type Memory module
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19
Features Registered
Voltage 1.2 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number HP 815097-B21, HP 1XD84AA
Manufacturer Warranty Limited lifetime warranty (Russia - 10 years)
Designed For HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL360 Gen10, DL380 Gen10, DL388 Gen10, DL560 Gen10, DL580 Gen10, ML110 Gen10, ML350 Gen10; Synergy 480 Gen10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£51.38
