We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Live the moment. Use the mouse, monitor and accessories that you’ve grown to love with your new notebook. With a single USB-C hub, you can connect up to 7 devices at once and keep your creativity flowing. The Nucleum has you covered whether you want to connect to a larger monitor or need to offload footage from the latest photo shoot. With the Nucleum, you can power up your laptop or MacBook* while also connecting to a USB Flash drive and charging an iPhone*. The compact size and built-in cable also make the Nucleum a perfect travel companion to take with you on location.
More Pixels
Use the HDMI port to output to a 4K UHD or Full HD 1080p monitor or projector.
Power pass-through
Get more juice for your iPhone, Bluetooth headphones and other devices.
Fill it up
Want to use all your connected devices at once? No problem, plug everything in and get creating!
Portable
The convenient size means you can bring the USB-C hub wherever you need it.
Creation station
Shoot, ingest and edit your footage wherever you are using the SD and microSD slots
Made to match
The Nucleum is designed to complement your new MacBook
Multiport adapter
No need to carry around multiple dongles to connect your devices.
Rugged cable
With the built-in cable, you have a connection to hand at all times.
Product Description | Kingston Nucleum - docking station - USB-C - HDMI | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | HDMI | Dimensions (WxDxH) | 4.5 cm x 12.7 cm x 1.42 cm | Weight | 92.4 g |
General | |
Width | 4.5 cm |
Depth | 12.7 cm |
Height | 1.42 cm |
Weight | 92.4 g |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SDXC UHS-II Memory Card , 1 (total) / 1 (free) x microSDXC UHS-I |
Interfaces | 2 x USB 3.1 Gen 1 , 1 x USB-C with Power Delivery , 1 x USB-C , 1 x audio / video - HDMI - 19 pin HDMI Type A |
Miscellaneous | |
Cables Included | 1 x USB-C cable - integrated |
Features | 4K Ultra HD, 60W power delivery |
