ITEM | QTY | PRICE |
HP DesignJet T250 Large-Format Printer
4 | £3,732.16 |
TCL 32" 32S5200K HD Smart Androi...
4 | £556.00 |
StarTech.com USB-C to Gigabit Adapter
4 | £118.08 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The essential addition to SSD-based laptops and all-in-one computers with limited storage capacity, the latest d2 USB-C desktop drive massively expands capacity to up to 10TB for professional bandwidth intensive creative applications. The LaCie d2 Professional performs perfectly on Macs and PCs alike and also features Seagate BarraCuda Pro enterprise-class hard drives for industry-leading performance and reliability.
Product Description | LaCie d2 Professional STHA10000800 - hard drive - 10 TB - USB 3.1 | Type | Hard drive - external (desktop) | Capacity | 10 TB | Interface | USB 3.1 - USB-C | Features | Security lock slot (cable lock sold separately), vibration dampening, LED status indicator, Enterprise | Power Source | Included AC adapter | Dimensions (WxDxH) | 130 mm x 60 mm x 188.5 mm | Weight | 1.4 kg | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty | Bundled with | Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 10 TB |
Interface | USB 3.1 |
Width | 130 mm |
Depth | 60 mm |
Height | 188.5 mm |
Weight | 1.4 kg |
Performance | |
Max Data Transfer Rate | 240 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | Adobe Creative Cloud (30 days trial) |
OS Required | Apple macOS Sierra 10.12 or later, Windows 10 or later |
Miscellaneous | |
Enclosure Material | Aluminium |
Dimensions & Weight (Shipping) | |
Shipping Width | 18 cm |
Shipping Depth | 24 cm |
Shipping Height | 12 cm |
Shipping Weight | 1.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
