Get maximum tracking accuracy from the most responsive optical sensor (PMW3366). Exclusive Logitech G Delta Zero optical sensor technology minimizes mouse acceleration and increases reliable targeting. Switch DPI modes on the fly - choose from five settings from 200 to 12,000 DPI. Customize to your advantage. Five 3.6g weights come with your Proteus Spectrum. Use some or all of them in the positions where you like more weight, or less. This mouse can be tailored to your preferences.
Product Description | Logitech Proteus Spectrum G502 - mouse - USB | Device Type | Mouse | Connectivity Technology | Wired - USB | Dimensions (WxDxH) | 7.5 cm x 4 cm x 13.2 cm | Weight | 168 g | Movement Detection Technology | Optical | Buttons Qty | 11 | Movement Resolution | 12000 dpi | Performance | 1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, 300 inches per second | Features | Programmable buttons, scrolling wheel, rubber side grips, sensitivity adjustment, adjustable weight, braided cable, 3 profiles, 16.8 million multi-colour illumination, ARM 32-bit processor | OS Required | Windows 8.1, Microsoft Windows 7 / 8 / 10 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 7.5 cm |
Depth | 4 cm |
Height | 13.2 cm |
Weight | 168 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 11 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | Weight modules (5 pcs.) |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
