Turn your iPad Pro into a laptop with one click! Enjoy laptop-like typing anywhere, day or night, with Slim Folio Pro for iPad Pro. Three distinct use modes ensure you can always work at your highest level no matter where you are - a café table, desk, or even your lap.
The light and durable all-in-one case also keeps your device protected from bumps, scratches, and spills. It even features a convenient spot to charge and stow your Apple Pencil (2nd gen).
Product Description | Logitech Slim Folio Pro - keyboard and folio case - QWERTY - UK Input Device | Device Type | Keyboard and folio case | Backlit | Yes | Interface | Bluetooth | Localization and Layout | QWERTY UK | Hot Keys Function | Multimedia, volume, search, brightness, home screen, battery check button | Protection | Scratch-resistant, spill-resistant | Dimensions (WxDxH) | 25.3 cm x 19.5 cm x 2.255 cm | Weight | 552.42 g | Manufacturer Warranty | 2-year warranty | Designed For | Apple 11-inch iPad Pro (1st generation) |
General | |
Backlit | Yes |
Keyboard Technology | Scissors |
Width | 25.3 cm |
Depth | 19.5 cm |
Height | 2.255 cm |
Weight | 552.42 g |
Carrying Case | |
Features | Magnetic closure, transformable into a stand for typing or viewing video, stylus holder, sleep/wake function, AutoSleep, protective corners |
Expansion / Connectivity | |
Interfaces | USB-C (charging) |
Battery | |
Type | Rechargeable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
