Whether you're editing a presentation or connecting with friends online, Sculpt Mobile Mouse is a comfortable, familiar companion for your modern, mobile lifestyle. Its compact design and BlueTrack technology, which works on virtually any surface, make it the ideal device for the office or on the go. Enjoy a clutter-free workspace at your desk or on your coffee table with this wireless, mini-USB connected mouse.
The classic shape of Sculpt Mobile Mouse and its 4-way scroll wheel make it intuitive to operate with either hand. Tilting the wheel left and right allows you to scroll horizontally, performing such tasks as navigating the Start screen or moving through wide documents with ease.
A mobile mouse optimized for Windows
The Windows button on Sculpt Mobile Mouse is an exciting new feature that operates seamlessly with Windows. Simply press the Windows logo to instantly view the Start Menu and access all of your favorite apps, just one click away.
The perfect travel companion
Whether you’re editing a presentation or connecting with friends online, Sculpt Mobile Mouse is a comfortable, familiar companion for your modern, mobile lifestyle. Its compact design and BlueTrack technology, which works on virtually any surface, make it the ideal device for the office or on the go. Enjoy a clutter-free workspace at your desk or on your coffee table with this wireless, mini-USB connected mouse.
Familiar design, high functionality
Product Description | Microsoft Sculpt Mobile Mouse - mouse - 2.4 GHz - flame red | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Flame red | Orientation | Right and left-handed | Dimensions (WxDxH) | 5.69 cm x 9.53 cm x 4.05 cm | Weight | 65 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 1000 ppi | Performance | 2400 fps | Features | Scrolling wheel (4-way), Microsoft BlueTrack Technology | Battery | 1 x AA type | OS Required | Microsoft Windows 7, Windows 8, Apple MacOS X 10.6 - 10.8, Windows RT | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 5.69 cm |
Depth | 9.53 cm |
Height | 4.05 cm |
Weight | 65 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Max Operating Distance | Up to 5 m |
Buttons Qty | 3 |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, EMC, MIC, FCC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP |
Battery | |
Type | AA type |
Technology | Alkaline |
Installed Qty | 1 |
Run Time (Up To) | 11 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 80% (non-condensing) |
