ITEM | QTY | PRICE |
Belkin Window + Dash Car Navigation M...
1 | £24.99 |
Say goodbye to Wi-Fi dead zones. Convenient, discreet and easy to install, extended Wi-Fi coverage is just an outlet away with this essentials edition extender. Boost your Wi-Fi for mobile devices and connect a wired device such as Smart TVs or game consoles.
Product Description | NETGEAR EX2700 - Essentials Edition - Wi-Fi range extender - Wi-Fi | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | United Kingdom | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | Dimensions (WxDxH) | 6.7 cm x 5.5 cm x 3.4 cm | Weight | 98 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.7 cm |
Depth | 5.5 cm |
Height | 3.4 cm |
Weight | 98 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 300 Mbps |
Features | Firmware upgradable, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Power | |
Power Device | Internal power supply |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
