Strong, consistent Wi-Fi is critical for the growth of your small business. WAC124 provides powerful Wi-Fi that is affordable, without added infrastructure and deployment costs. It delivers the performance to keep your company, employees, and customers connected. WAC124 is built for easy installation.
Product Description | NETGEAR WAC124 - wireless router - Wi-Fi 5 - Wi-Fi 5 - desktop, wall-mountable | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop, wall-mountable | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Capacity | SSIDs total: 3 , Maximum number of clients: 64 | Features | Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Wi-Fi Protected Setup (WPS), reset button, beamforming technology, guest access, Airtime Fairness, 4x4 MU-MIMO technology, bridge mode, Point-to-Point Protocol (PPP), Point-to-Multipoint (PtMP) link mode | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac | Power | DC 12 V | Dimensions (WxDxH) | 23.551 cm x 15.076 cm x 5.45 cm | Weight | 377 g | Localisation | United Kingdom | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-PSK, WPA2-PSK, WEP |
Authentication Method | Basic Service Set Identifier (BSSID) |
Wi-Fi Rating | AC2000 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac, Plug and Play, EN 60950 |
Status Indicators | Power, USB, Internet, Wi-Fi |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Aerial | |
Aerial | External |
Antenna Qty | 3 |
Gain Level | 3 dBi |
Power | |
Power Device | External power adapter - 18 Watt |
Voltage Required | DC 12 V |
Power Consumption Operational | 16.2 Watt |
Miscellaneous | |
Cables Included | 1 x network cable |
Dimensions & Weight | |
Width | 23.551 cm |
Depth | 15.076 cm |
Height | 5.45 cm |
Weight | 377 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 3 years - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
