We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Put three layers of rugged protection between your tablet and the world. This case is made to protect from heavy use, drops and tumbles.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
Product Description | OtterBox Defender Series - protective case for tablet | Product Type | Protective case for tablet | Screen Size Compatibility | 9.7" | Material | Polyurethane, polycarbonate, foam, synthetic rubber | Colour | Black |
General | |
Rugged | Yes |
Colour | Black |
Carrying Case | |
Type | Protective case |
Recommended Use | For tablet |
Protection | Shockproof, dust-resistant, scratch-resistant, dirt-resistant, impact protection, drop-proof |
Included Accessories | Shield stand |
