Scaling mountain peaks, racing desert dunes, paddling coastal breaks - your LifeProof case is geared up to get you through amazing adventures in the toughest terrain.
Product Description | LifeProof Fre - protective waterproof case for mobile phone | Product Type | Protective waterproof case for mobile phone | Dimensions (WxDxH) | 8.89 cm x 1.168 cm x 17 cm | Weight | 46.72 g | Colour | Black | Underwater Depth | Up to 2 m | Manufacturer Warranty | 1-year warranty |
General | |
Width | 8.89 cm |
Depth | 1.168 cm |
Height | 17 cm |
Weight | 46.72 g |
Underwater Use | Yes |
Colour | Black |
Carrying Case | |
Type | Protective waterproof case |
Recommended Use | For mobile phone |
Protection | Weatherproof, dirt-resistant, drop-proof, snowproof |
Max Height of Shock Resistance | 2 m |
Manufacturer Warranty | |
Service & Support | 1 year |
