Live outside the limits and document your deeds with Fre. Fully sealed with a built-in screen cover, this case gives you the freedom to push extremes.
Product Description | LifeProof FRE - protective waterproof case for mobile phone | Product Type | Protective waterproof case for mobile phone | Dimensions (WxDxH) | 8.255 cm x 1.473 cm x 15.672 cm | Weight | 42.4 g | Colour | Avalanche white | Underwater Depth | Up to 2 m | Manufacturer Warranty | 1-year warranty | Designed For | Samsung Galaxy S7 |
General | |
Width | 8.255 cm |
Depth | 1.473 cm |
Height | 15.672 cm |
Weight | 42.4 g |
Underwater Use | Yes |
Carrying Case | |
Type | Protective waterproof case |
Recommended Use | For mobile phone |
Protection | Waterproof, shockproof, dirt-resistant, vibration-proof, drop-proof, snowproof |
Included Accessories | Headphones adapter, microfibre cleaning cloth |
Compliant Standards | IEC 60529 IP68, MIL-STD 810G 516.6 |
Manufacturer Warranty | |
Service & Support | 1 year |
Compatibility Information | |
