LifeProof SLAM merges intense drop protection with modern styling. When it takes a tumble, it dances back from danger with a streamlined suit of armor that rocks every roll and struts any style. When you pull it from your pocket, its sleek shape and burst of color captivates. SLAM pulls double duty so you can go extra hard.
Product Description | LifeProof SLAM Apple iPhone 7/8 - back cover for mobile phone | Product Type | Back cover for mobile phone | Dimensions (WxDxH) | 7.493 cm x 1.092 cm x 14.605 cm | Weight | 36 g | Material | Polycarbonate | Colour | Aloha sunset | Image Colour Disclaimer | The displayed product image may be a different colour | Designed For | Apple iPhone 7, 8 |
General | |
Width | 7.493 cm |
Depth | 1.092 cm |
Height | 14.605 cm |
Weight | 36 g |
Carrying Case | |
Type | Protective cover |
Recommended Use | For mobile phone |
Protection | Drop-proof |
Cover Type | Back cover |
Compliant Standards | MIL-STD 810G 516.6 |
Max Height of Shock Resistance | 2 m |
Compatibility Information | |
