Expand your storage with a compact fit designed to plug in and stay. Read speeds up to 300 MB/s with the USB 3.1 standard.
Product Description | Samsung FIT Plus MUF-256AB - USB flash drive - 256 GB | Product Type | USB flash drive | Interface Type | USB 3.1 | Storage Capacity | 256 GB | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 300 MB/s |
Features | Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, key ring loop |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 23.6 mm |
Depth | 7.3 mm |
Height | 18.8 mm |
Weight | 3.1 g |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
