Enjoy this protective cover, intended to enhance user experience thanks to its intuitive functionality. From incoming calls to music playback controls, you can control the essentials with the cover closed. With a practical design, that features all-round protection, you can rest assured, that every corner and side of your device is safeguarded from frustrating scratches and bumps.
Product Description | Samsung Clear View Cover EF-ZA520 - flip cover for mobile phone | Product Type | Flip cover for mobile phone | Dimensions (WxDxH) | 7.37 cm x 1.3 cm x 14.8 cm | Weight | 50 g | Colour | Blue | Designed For | Galaxy A5 |
General | |
Width | 7.37 cm |
Depth | 1.3 cm |
Height | 14.8 cm |
Weight | 50 g |
Colour | Blue |
Carrying Case | |
Type | Protective cover |
Recommended Use | For mobile phone |
Cover Type | Flip cover |
Open Type | Side |
Compatibility Information | |
Designed For | Samsung Galaxy A5 |
