Know when there’s movement in your home.
Add smartness to your home with a SmartThings Motion Sensor. Receive alerts if there’s unexpected movement, set connected devices to turn on and off as people come and go, and much more. Also monitors temperature. Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. Connected devices sold separately.
SmartThings is the easy way to turn your home into a smart home.
In the Box
Requirements
Technical Information
Product Description | Samsung SmartThings - motion sensor - ZigBee 3.0 - white | Product Type | Motion sensor | Functions | Motion detection | Power Source | Battery | Internet of Things (IoT) Platform | SmartThings | Connectivity | Wireless - ZigBee 3.0 | Colour | White | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 5.66 cm x 5.02 cm x 5.57 cm |
General | |
Connectivity Technology | Wireless - ZigBee |
Max Range Indoors | 40 m |
OS Required | Android 6.0 (Marshmallow) or later, Apple iOS 11 or later |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Motion Sensor | |
Detection Range | 4.6 m |
Battery | |
Form Factor | CR2 |
Battery Included | Yes |
Required Qty | 1 |
Miscellaneous | |
Included Accessories | Adhesive strips, magnetic wall mount |
Colour | White |
Dimensions & Weight | |
Width | 5.66 cm |
Depth | 5.02 cm |
Height | 5.57 cm |
Weight | 95 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
