Lightning-fast performance and titanic storage give your desktop or creative professional system the edge you need to be your very best.
Product Description | Seagate Barracuda Pro ST12000DM0007 - hard drive - 12 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 12 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, Worldwide Name (WWN), advanced format 512e, Perpendicular Recording, S.M.A.R.T. | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 705 g | Manufacturer Warranty | 5-year warranty | Bundled with | 2 years Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - internal |
Capacity | 12 TB |
Bytes per Sector | 4096 |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 705 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 250 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 1,000,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 7.8 Watt (active) , 4.83 Watt (idle) , 0.84 Watt (standby) , 0.8 Watt (sleep) |
Software & System Requirements | |
Software Included | Seagate SeaTools |
Miscellaneous | |
Compliant Standards | BSMI, ICES-003, EN55024, EN55022 Class B, RoHS, China RoHS, RCM, ASTM B845, FCC Part 15 J Class B, ACMA, Directive 2014/30/EU, ANSI C63.4-2014, AS/NZS CISPR 32 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (operating) | 70 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 250 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.5 g @ 22-350 Hz |
Vibration Tolerance (non-operating) | 2.27 g @ 2-500 Hz |
