We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives are enhanced with AgileArray technology for optimal reliability and system scalability.
Product Description | Seagate IronWolf Pro ST8000NE001 - hard drive - 8 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 8 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 722 g | Manufacturer Warranty | 5-year warranty | Bundled with | 2 years Rescue Data Recovery Service Plan |
General | |
Device Type | Hard drive - internal |
Capacity | 8 TB |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 722 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 214 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 1,200,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 5.9 Watt (idle) , 9.8 Watt (active) , 0.9 Watt (standby) , 0.8 Watt (sleep) |
Software & System Requirements | |
Software Included | IronWolf Health Management |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 70 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
Vibration Tolerance (non-operating) | 2.27 g @ 10-500 Hz |
