Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH1GN Cat 6 Patch Cable (1 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
Product Description | StarTech.com 1ft CAT6 Ethernet Cable, 10 Gigabit Molded RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable with Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (C6PATCH1GN) - patch cable - 30 cm - green | Type | Patch cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded | Length | 30 cm | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Green | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ST1000SMPEX |
General | |
Network Cable Type | Patch cable - CAT 6 |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Features | Molded |
Length | 30 cm |
Colour | Green |
Connectivity | |
Miscellaneous | |
Compliant Standards | CSA, ETL - up to 650 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
