Connect to your external solutions and transfer data at 10x the speed of USB 2.0. StarTech.com's 1-foot USB 3.0 cable (A-B, male-male) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the 1-foot USB 3.0 cable supports a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 1-foot USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
Product Description | StarTech.com 1 ft / 30cm SuperSpeed USB 3.0 Cable A to B - USB 3 A (m) to USB 3 B (m) (USB3SAB1) - USB cable - USB Type A to USB Type B - 30.5 cm | Type | USB cable | Technology | Shielded twisted pair (STP) | Features | 5 Gbps data rate | Length | 30.5 cm | Connector | 9 pin USB Type A - male | Connector (Second End) | 9 pin USB Type B - male | Compliant Standards | USB 3.0 | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: 35BAYUSB3S4, ECUSB3S22, FCREADHCU3, S3510BMU33, S3510SMU33, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, S3540BU33E, S355BU33ERM, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, ST4300U3C3, ST7300USB3B |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Length | 30.5 cm |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
