Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH10GR Cat 6 Patch Cable (10 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
Product Description | StarTech.com 10ft CAT6 Ethernet Cable, 10 Gigabit Molded RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable with Strain Relief, Gray, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (C6PATCH10GR) - patch cable - 3 m - grey | Type | Patch cable - CAT 6 | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded | Length | 3 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6 |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Features | Molded |
Length | 3 m |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | CSA, ETL - up to 650 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
