Connect analog or dual mode Flat Panel Displays to a PC or Mac with a DVI Analog Video Card. This 10ft DVI to VGA Monitor Cable features a DVI (analog) male connector and a VGA (High Density D-Sub) male connector, providing a cost-effective way to connect an analog or dual mode Flat Panel Display to a PC or Mac computer with a DVI Analog Video Card.
Product Description | StarTech.com 10 ft DVI to VGA Display Monitor Cable - DVI to VGA connector - 10ft DVI to VGA Cable - DVI to VGA Converter (DVIVGAMM10) - video cable - 3 m | Type | Video cable | Length | 3 m | Connector | HD-15 (VGA) - male | Connector (Second End) | DVI-A - male | Compliant Standards | FCC | Colour | Black | Designed For | P/N: SV431DD2DU3A |
General | |
Length | 3 m |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 12+5 pin analogue DVI - male |
Miscellaneous | |
Compatibility Information | |
