Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PATCH100B Cat5e Patch Cable (100 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description | StarTech.com 100 ft Cat5e Patch Cable with Molded RJ45 Connectors - Blue - Cat5e Ethernet Patch Cable - 100ft UTP Cat 5e Patch Cord (M45PATCH100B) - patch cable - 30.4 m - blue | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568A | Wires per Cable | 8 wires | Features | Molded | Length | 30.4 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: BR4100DC, DS16105, NETRS232, NETRS2321POE, RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121UTPDVGB, STUTPRXL, USB110EXT, USB110EXT2, USB120EXT |
General | |
Network Cable Type | Patch cable - CAT 5e |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Features | Molded |
Length | 30.4 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
