Extend your VGA monitor connection without losing video signal quality. The MXTHQ15M High Resolution VGA Extension Cable (15-meter) is designed to extend your VGA video connection while maintaining the highest video quality possible through VGA.
Ideally suited for high resolution VGA video applications, this high quality coaxial VGA extension cable (HD15 to HD15, M-F) helps eliminate the picture ghosting and fuzzy images that are inherent to non-coaxial cables, and features ferrite cores near the VGA connector ends to protect against EMI interference.
Product Description | StarTech.com 15m Coax High Resolution Monitor VGA Video Extension Cable - VGA extension cable - 15 m | Type | VGA extension cable | Technology | Triple shielded twisted pair coaxial | Features | Molded, strain relief, ferrite core | Length | 15 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - female | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 28 |
Length | 15 m |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
