Charge and sync your Apple devices in their protective cases, even in hard to reach areas and tight spaces. The USB2ADC1MUR Apple (30-pin) Dock Connector to Right Angle USB Cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
The right-angled USB connector allows for connection in tight spaces while the stepped Apple Dock Connector, designed by StarTech.com, plugs into your iPhone, iPod or iPad even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This durable cable is Apple MFi certified .
As an alternative, StarTech.com also offers a 1m Apple 30-pin Dock Connector to Left Angle USB Cable (USB2ADC1MUL), which provides the same convenience as this right-angled cable, but allows you to connect to your PC or Mac computer or your USB wall/vehicle charger from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description | StarTech.com 1m Apple 30-pin Dock to Right Angle USB Cable iPhone iPod iPad - charging / data cable - 1 m | Cable | Charging / data cable | Technology | Shielded | American Wire Gauge (AWG) | 22/30 | Length | 1 m | Colour | White | Connector | Apple Dock - male | Connector (Second End) | USB - male | Features | Right-angled connector | Manufacturer Warranty | Limited lifetime warranty | Designed For | Apple iPod (4G, 5G); iPod classic; iPod mini |
General | |
Cable Type | Charging / data cable right-angled connector |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 1 m |
Plated Connector | Nickel |
Features | Sync and charge |
Colour | White |
Connectivity | |
Connector | Apple Dock connector - male |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | RoHS, MFI |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
Designed For | Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini |
