Charge your tablet and your cell phone simultaneously, in your car. Charge your phone and your tablet simultaneously, while you're in your car driving. This dual-port car charger features two USB 2.0 ports - one 1A port for charging your smartphone or iPhone and one 2.4A port for charging your iPad or other tablet.
Plus, when you're traveling with a passenger, having the second USB charge port available means that you can charge two phones simultaneously and ensure that both of your mobile devices are ready when you arrive.
Product Description | StarTech.com Dual Port USB Car Charger High Power (17 Watt / 3.4 Amp) car power adapter - USB - 17 Watt | Product Type | Car power adapter | Dimensions (WxDxH) | 2.39 cm x 5.84 cm x 1.88 cm | Weight | 42 g | Colour | White | Output Connector Type | Total 2: USB | Voltage Required | 12 - 24 V | Voltage Provided | 5 V | Max Electric Current | 3.4 A | Power Provided | 17 Watt | Manufacturer Warranty | 2-year warranty | Designed For | P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA |
General | |
Designed For | Tablet, mobile phone |
Width | 2.39 cm |
Depth | 5.84 cm |
Height | 1.88 cm |
Weight | 42 g |
Enclosure Colour | White |
Power Device | |
Input Connectors | Automobile cigarette lighter |
Input Connectors Qty | 1 |
Output connectors | Total 2: 4 pin USB Type A |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
