Connect to your external solutions and transfer data at 10x the speed of USB 2.0. StarTech.com's 3ft Black SuperSpeed USB 3.0 cable (A-B, male-male) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the 3ft USB 3.0 cable offers a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 3ft USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
Product Description | StarTech.com 3 ft / 91cmm Black SuperSpeed USB 3.0 Cable A to B - USB 3 A (m) to USB 3 B (m) (USB3SAB3BK) - USB cable - USB Type A to USB Type B - 91 cm | Type | USB cable | Technology | Shielded twisted pair (STP) | Features | Molded, 5 Gbps data rate | Length | 91 cm | Connector | 9 pin USB Type A - male | Connector (Second End) | 9 pin USB Type B - male | Compliant Standards | USB 3.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: HB20A4AME, HB20A7AME, HBS304A24A, S352BU313R, S352BU33HR, S355BU33ERM, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, ST103008U2C, ST7300USBME, ST93007U2C, SV231DPU34K, SV431DD2DU3A, SV431DHD4KU, SV431DL2DU3A, SV431DPU3A2, SV431HDU3A2 |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Length | 91 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: ECUSB3S22, ECUSB3S254F, FCREADHCU3, HB20A4AME, HB20A7AME, HBS304A24A, MPEXUSB3S22B, PCIUSB3S22, PCIUSB3S4, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, S3510BMU33, S3510SMU33, S3520BU33ER, S352BU313R, S352BU33HR, S355BU33ERM, SATDOCK4U3RE, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST4300USBM, ST7300USB3B, ST7300USBME, ST93007U2C, SV231DPU34K, SV431DD2DU3A, SV431DHD4KU, SV431DL2DU3A, SV431DPU3A2, SV431HDU3A2 |
