This high quality USB 2.0 cable (A to Mini B) provides one (4-pin) USB Type A male connector and one Mini B (5-pin) male connector, and can support data high speed USB 2.0 transfer rates of up to 480Mbps.
A high quality replacement for connecting your digital camera (Canon, Sony, Hewlett-Packard) to a host computer, this USB A to Mini B cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A to Mini B USB 2.0 cable provides pure digital data transfers for sharper, more natural images and sound at higher speeds.
Product Description | StarTech.com 3 ft. (0.9 m) USB to Mini USB Cable - USB 2.0 A to Mini B - White - Mini USB Cable (USB2HABM3) - USB cable - USB to mini-USB Type B - 91 cm | Type | USB cable | Length | 91 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | Mini-USB Type B - male | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, DPBOOST, HDBOOST4K, HDBOOST4K2, KITBXAVHDPNA, KITBXDOCKPNA, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, NOTECONS02, NOTECONS02X, ST121HDBTU, ST121USBHD, ST121WHD2, ST124HDBT, SV231USBLC, SV565FXHD4KU, SV565HDIP, USB2002EXT2, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK |
General | |
Type | USB cable |
Length | 91 cm |
Connectivity | |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, DPBOOST, HDBOOST4K, HDBOOST4K2, KITBXAVHDPNA, KITBXDOCKPNA, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, NOTECONS01, NOTECONS02, NOTECONS02X, SATDOCK25U, ST121HDBTU, ST121USBHD, ST121WHD2, ST124HDBT, SV231USBLC, SV565FXHD4KU, SV565HDIP, USB2002EXT2, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4 |
