ITEM | QTY | PRICE |
Jabra Dealer Board Cable - R9-RJ6
3 | £46.02 |
Connect a USB 3.0 Micro USB External Hard drive to your PC or laptop. The USB3SAUB3 3-foot SuperSpeed USB 3.0 Cable (A to Micro B) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the USB 3.0 A to Micro B cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication to provide a quick and easy way to connect to an external storage solution with astounding throughputs of up to 5Gbps (when used with a USB 3.0 host and device).
Product Description | StarTech.com 3 ft. (0.9 m) USB 3.0 to Micro B Cable - SuperSpeed USB 3.0 5Gbps - Shielded USB A to USB Micro B - Blue - USB 3.0 Cable (USB3SAUB3) - USB cable - USB Type A to Micro-USB Type B - 90 cm | Type | USB cable | Technology | Shielded | Features | 5 Gbps data rate | Length | 90 cm | Connector | 9 pin USB Type A - male | Connector (Second End) | 10 pin Micro-USB Type B - male | Compliant Standards | USB 3.0 | Colour | Black, silver | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: DKT30CVAGPD, HBS304A24A, S2510BMU33, S2510BPU33, S2510BPU337, S2510BU33PW, S251BMU3FP, S251BRU33, S251BU31315, S251SMU33EP, S252BU313R, SLSODDU33B, SM21BMU31C3, SM22BU31C3R, SM2NGFFMBU33, SMS2BU31C3R, ST4300MINU3B, ST4300MINU3W, ST4300U3C1, ST4300U3C1B, UNI251BMU33, USB31000S2H, USB31000SA |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Length | 90 cm |
Connectivity | |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: DKT30CVAGPD, ECUSB3S11, ECUSB3S22, ECUSB3S254F, HBS304A24A, PCIUSB3S22, PCIUSB3S4, S2510BMU33, S2510BPU33, S2510BPU337, S2510BU33PW, S251BMU3FP, S251BRU33, S251BU31315, S251SMU33EP, S252BU313R, SAT2510BU32, SLSODDU33B, SM21BMU31C3, SM22BU31C3R, SM2NGFFMBU33, SMS2BU31C3R, ST3300U3S, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C1, ST4300U3C1B, UNI251BMU33, USB31000S2H, USB31000SA |
