StarTech.com 35 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Key features
  • High quality 24 AWG copper wire
  • ETL Verified
  • HIGH PERFORMANCE CAT6 ETHERNET CABLE: 100% copper for error-free Multi Gigabit 1/2.5/5Gbps connections; 10Gbps up to 160'; Fluke patch cord tested to comply w/ANSI/TIA-568-2.D Category 6; ETL Verified
  • POE SUPPORT: 24 AWG stranded copper conductors & UL Rated Wiring (E132276-A) supports up to 100W for PoE devices like VOIP phone & security systems; IEEE 802.3bt & DTE power compliance reduces cable heating
  • QUALITY CONSTRUCTION: ETL & UL certified wire; 50-micron gold-plated connectors prevent rust/corrosion to avoid costly network downtime; High quality PVC jacket resists bending or fraying damage
  • EASY INSTALLATION: 35 foot snagless patch cord for easy installation & flexible disconnection in wiring conduits; Compatible w/Cat5e & earlier standards; Molded boots available for constrained spaces
Product codes
chevron icon
chevron icon
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH35BK Cat 6 Patch Cable (35 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable black PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
chevron icon
Product Description StarTech.com 35ft CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Black, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATCH35BK) - patch cable - 10.7 m - black
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Molded, snagless
Length 10.7 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Black
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
