Add a 10/100Mbps Ethernet port to a USB enabled computer system. This compact USB 2.0 to 10/100 Mbps Ethernet USB network adapter offers convenient Ethernet connectivity - simply connect the network adapter to an available USB 2.0 port on your laptop computer, then connect the adapter to the Ethernet network.
Providing full/half duplex operation on both 10Mbps or 100Mbps Ethernet connections, this USB 2.0 Ethernet adapter supports data transfer rates of up to 200Mbps, providing a fully integrated, cost-effective and reliable solution to notebook users requiring Ethernet connectivity.
Product Description | StarTech.com USB To Ethernet Adapter - 10/100Mbps Ethernet - USB 2.0 - Black - USB Ethernet Adapter (USB2106S) - network adapter - USB 2.0 - 10/100 Ethernet | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Ports | 10/100 Ethernet | Dimensions (WxDxH) | 2.2 cm x 6.8 cm x 2.6 cm | Weight | 22 g | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX | Data Link Protocol | 10Mb LAN, 100Mb LAN | Data Transfer Rate | 100 Mbps | Compliant Standards | IEEE 802.3, IEEE 802.3u | Colour | Black | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14 | Manufacturer Warranty | 1-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet |
Status Indicators | Port transmission speed, link OK |
Features | Flow control, wake on LAN (WOL), full duplex mode |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 - female |
Miscellaneous | |
Compliant Standards | RoHS |
Colour | Black |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14 |
Dimensions & Weight | |
Width | 2.2 cm |
Depth | 6.8 cm |
Height | 2.6 cm |
Weight | 22 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
The following resources are available for the StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter
