Easily connect and hot swap dual 2.5" and 3.5" SATA/SAS hard drives from a 5.25" bay. The HSB2535SATBK Removable 2-drive backplane lets you quickly install and hot-swap drives from the front of your computer, by turning a 5.25" bay into a hot-swappable SATA/SAS interface for you to connect a 3.5" SATA hard drive (HDD) and/or a 2.5" SATA hard drive or solid state drive (SSD).
The hard drive bay interfaces with SATA/SAS, offering two trayless hard drive bays and can be mounted into any 5.25" front bay, to provide a hot-swappable mobile rack. The bays feature ejection levers which allow drives to be installed and removed quickly from the computer system, providing a convenient way to create backups that can then be removed for safekeeping, archiving, or external portable access.
For added versatility the backplane provides support for both SATA and SAS interfaces, an ideal accommodation for enterprise system integration. Plus, to help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan and slotted aluminum enclosure.
Product Description | StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack Backplane for 2.5" and 3.5" SATA/SAS HDD or SSD with Fan (HSB2535SATBK) - storage bay adapter - SATA 6Gb/s / SAS 6Gb/s | Device Type | Storage bay adapter | Expansion Bays | 1 x hot-swap - 3.5" , 1 x hot-swap - 2.5" x 1/8H | Compatible Bay | 1 5.25" x 1/2H | Interface | SATA 6Gb/s / SAS 6Gb/s | Dimensions (WxDxH) | 18.26 cm x 14.8 cm x 4.2 cm | Weight | 520 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: 25SAT35HDD, PEXMSATA3422, PEXMSATA343 |
General | |
Storage Controller | |
Processor | No CPU |
Expansion / Connectivity | |
Interfaces | 2 x SATA 6Gb/s / SAS 6Gb/s |
Connections | 2 - 7 pin external Serial ATA , 1 - 4 PIN internal power |
Compatible Bay | 1 x internal 5.25" x 1/2H |
Miscellaneous | |
Cables Included | 1 x power cable , 2 x Serial ATA cable - 45.72 cm |
Mounting Kit | Included |
Compliant Standards | FCC, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 18.26 cm |
Depth | 14.8 cm |
Height | 4.2 cm |
Weight | 520 g |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
