Create an external dual 3.5in SATA HDD RAID array you can access over a Gigabit LAN using WebDAV, FTP, and Windows Share services. The S352BMU3N 2-Bay NAS RAID enclosure enables you to build a secure external RAID array with two 3.5" SATA hard drives, and connect it directly to your Gigabit network without a host computer for fast network wide access.
For broad device compatibility, this NAS enclosure features WebDAV allowing you to access files from any web browser-enabled device on the network, such as a computer, Tablet, IPhone, or smartphone. Third party mobile apps are also supported for intuitive and familiar file management.
For hassle-free media integration, the enclosure supports UPnP, and DLNA allowing you to instantly stream videos, photos, and Music directly to a supporting smart televisions, Blu-Ray /Set-top box, and Video Game Consoles.
To achieve greater performance or secure data redundancy the enclosure features a built-in hardware RAID controller, supporting RAID 0, 1, and JBOD.
For easier file sharing, the enclosure supports FTP and SMB services, enabling you to publicly share files over the network or Internet, with the client software of choice.
Increase speed locally with USB DAS (Direct-Attached Storage), enabling you to connect the enclosure to your computer using USB 3.0 to provide transfer speeds up 5 Gbps.
The S352BMU3N maximizes both durability and reliability with a built-in fan, solid aluminum construction.
Product Description | StarTech.com Dual Bay Gigabit NAS RAID Enclosure for 3.5" SATA Hard Drives w/ WebDAV and Media Server - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 2 (max) | Dimensions (WxDxH) | 11.55 cm x 18.05 cm x 8.5 cm | Weight | 1.2 kg () | Localisation | North America, United Kingdom, Europe | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, JBOD | Networking | Network adapter 10Mb LAN, 100Mb LAN, GigE | Power | AC 120/230 V | System Requirements | Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M5NA |
General | |
Total Storage Capacity | 0 GB |
Width | 11.55 cm |
Depth | 18.05 cm |
Height | 8.5 cm |
Enclosure Colour | Black |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD - 3.5" |
Networking | |
Type | Network adapter |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Features | DLNA Media Server, WebDAV server |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type B |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Software / System Requirements | |
OS Required | Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
