Samsung TV Promotion: Save up to £250 across the range.
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount
£172.40
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Mount two 12” to 24” displays (max weight of 30.0 lb./13.6 kg per display)
  • Dual articulating arms provide a wide range of motion
  • 360° rotation around the support pole and at the elbow, 180° rotation at the shoulder
  • Accessory Type: Bracket
Product codes
chevron icon
chevron icon
Mount two displays on your desk surface or through a grommet, with adjustable height and cable management. The ARMDUAL Articulating Dual Monitor Arm lets you mount two displays to your desk or table, with extension, tilt, pan, swivel, pivot and height adjustments.
The desk-mount monitor arm offers a wide range of motion on several axes, giving you the freedom to place your displays side-by-side, spread apart, back-to-back or anywhere in between. For viewing longer pages or blocks of code without scrolling, the dual arm also supports landscape to portrait display rotation for either monitor.
Mounting your displays on a dual monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 30lbs (13.6kg) per arm, the dual arm monitor mount holds your displays with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile dual-monitor mounting solution.
chevron icon
Product Description StarTech.com Desk Mount Dual Monitor Arm - Articulating - Supports Monitors 12" to 24" - Adjustable VESA Monitor Arm - Grommet or Desk Mount - Black (ARMDUAL) mounting kit - adjustable arm - for 2 LCD displays - black
Product Type Mounting kit (adjustable arm) - desk-mountable
Tilt -90° to 90°
Pan -90° to 90°
Rotation 360°
Adjustments Height, pan, tilt, swivel, rotation
Weight 4 kg
Recommended Use 2 LCD displays
Recommended Display Size 12"-24"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 13.6 kg
Material Plastic, steel
Colour Black
Package Content 8 x M4x12 screws, allen wrench (4mm), 8 x spacers, desk clamp, grommet plate, 2 x cable-management clips, allen wrench (2.5mm), DEK, 2 x cover plates, 8 x M4x25 screws, 2 x M6x12 screws, 2 x M6 washers, 4 x gasket cushions, allen wrench (6mm)
Manufacturer Warranty 5-year warranty
Designed For P/N: ACCSMNT, ARMSTS, ARMSTSLG, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£172.40
