Capture and convert an S-Video or Composite video on your PC or Mac as digital media. The SVID2USB23 USB 2.0 S-Video & Composite Video Capture Cable offers an easy to use analog video capture solution, enabling you to grab video from an S-Video or Composite video source, as well as the accompanying 2-channel RCA audio, to your Mac or Windows computer.
The cable connects to your desktop or laptop computer through USB 2.0, and is compact enough to fit in the palm of your hand, providing a conveniently portable video capture solution that's more than suitable for use with laptops and desktop computers alike.
An easy-to-use device for recording analog video to your computer from external sources, such as a VCR or camcorder the SVID2USB23 offers the perfect solution for Betamax or VHS video capture, with real-time MPEG-1, MPEG-2, and MPEG-4 encoding, as well as TWAIN support, to ensure compatibility with a wide range of systems and software.
Product Description | StarTech.com Composite to USB Video Capture - S Video Converter / Analog to Digital Video Adapter with TWAIN and Mac Support (SVID2USB23) - video capture adapter - USB 2.0 | Device Type | Video capture adapter | Interface Type | USB 2.0 | Weight | 60 g | Colour | Black | Video Input | S-video input, composite video input | Analogue Video Format | NTSC, SECAM, PAL | Analogue video Signal | S-Video, composite video | Digital Video Format | MPEG-1, MPEG-2 | Digital Video Capture Resolution | 720 x 480, 720 x 576 | OS Required | Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits) | Manufacturer Warranty | 1-year warranty |
General | |
Weight | 60 g |
Colour | Black |
Video | |
Interface Type | S-video input, composite video input |
Expansion / Connectivity | |
Interfaces | 1 x display / video - composite video input - RCA , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - input - RCA x 2 |
Connections | 1 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 5 - 85% (non-condensing) |
