Add two 2.5" SATA HDDs, up to 15mm in height, to your Mac or PC through Thunderbolt, with a well-ventilated storage solution that helps keep your drives running cool. The S252SMTB3 2-bay enclosure features thunderbolt technology that maximizes the performance of your external drives by enabling you to connect two 2.5" SATA I/II/III hard drives (HDD) or solid state drives (SSD) to your Mac or PC using an available Thunderbolt port.
Transfer data to and from your external drives faster than ever before, through a Thunderbolt connection. With data transfer speeds up to 10 Gbps, Thunderbolt performs 100% faster than USB 3.0 (5 Gbps), and 60% faster than eSATA (6Gbps). The unprecedented performance thunderbolt offers makes this enclosure an ideal solution for high-resolution video editing and photography applications.
To save you time and money, the S252SMTB3 includes a high-quality 1m Thunderbolt cable, ensuring you have everything you need for a hassle-free installation.
To help ensure optimal operating temperatures for your hard drives and solid state drives, the Thunderbolt enclosure features a built-in fan and a durable, solid aluminum housing that maximizes heat dissipation.
Get the most out of your Thunderbolt technology by leveraging its daisy chain port. You can connect up to 6 additional devices such as monitors, docking stations, or additional external drives. This is an excellent docking solution for Ultrabooks or smaller more portable laptops that have fewer I/O ports.
Product Description | StarTech.com Thunderbolt Dual Hard Drive Enclosure with Thunderbolt Cable - storage enclosure - SATA 6Gb/s - Thunderbolt | Device Type | Storage enclosure - external | Bus Type | Thunderbolt | Colour | Silver | Expansion Bays | 2 x internal - 2.5" | Hard Drive Form Factor Compatibility | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 10 GBps | Supported Devices | Hard drive | Max Storage Devices Qty | 2 | Product Material | Aluminium | System Requirements | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) | Dimensions (WxDxH) | 9.3 cm x 13.3 cm x 6.3 cm | Weight | 490 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M5NA, TB2DOCK4K2DP |
General | |
Host Bus | Thunderbolt |
Colour | Silver |
Storage Controller | |
Expansion / Connectivity | |
Interfaces | 2 x SATA 6Gb/s - SATA combo |
Connections | 1 x Thunderbolt output |
Miscellaneous | |
Cables Included | 1 x Thunderbolt cable - external |
Features | Built-in cooling fan |
Compliant Standards | FCC, RoHS |
Power | |
Type | Power adapter |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 9.3 cm |
Depth | 13.3 cm |
Height | 6.3 cm |
Weight | 490 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% |
Compatibility Information | |
