Dock up to two 2.5" or 3.5" SATA SSDs/HDDs in a stylish white docking station with an integrated 2-port USB 3.0 hub. The SDOCK2U33HFW USB 3.0 Dual hard drive dock with Fast Charge USB hub enables two SATA 2.5in or 3.5in hard drives (HDD) or solid state drives (SSD) to be connected simultaneously to a computer through USB, while controlling the power status (on/off) of each individual drive independently from the other. The enclosure supports UASP and delivers optimal performance with a USB 3.0 connection, but is also backward compatible with USB 2.0/1.1 host connections.
The Hard Drive Dock features a built-in 2-port USB 3.0 Hub that enables you to connect up to 2 additional USB 3.0 devices to your computer through the same USB connection. One of the ports on the hub also has Fast Charging capabilities, that charges iPads and other mobile devices as effectively as through a wall plug. This Fast Charge Port has been specially designed for compatibility with a wide range of tablets and smartphones.
With support for UASP, the dock performs up to 70% faster than conventional USB 3.0, when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, large capacity drives (tested up to 4TB), and 2.5in or 3.5in hard drives this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer. Plus, configurable power management reduces energy consumption, and extends the life of your drives by avoiding unnecessary access.
The docking station features a built-in 80mm cooling fan that helps increase reliability and lifespan of HDDs by keeping the drives cooler. The variable fan speed control allows for on-the-fly adjustments for any type of HDD, or to balance cooling with noise.
Extend the value of this docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
With uniform white design and sleek silver trim, the SDOCK2U33HFW will look great with your Apple Mac.
Product Description | StarTech.com USB 3.0 Dual SATA HDD Dock w/ Fast Charge USB Hub UASP and Fan - storage controller - SATA 6Gb/s - USB 3.0 | Device Type | Storage controller - external | Bus Type | USB 3.0 | Colour | White & silver | Expansion Bays | 2 x hot-swap - 2.5" / 3.5" shared | Hard Drive Form Factor Compatibility | 2.5", 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, solid state drive | Power | AC 120/230 V | System Requirements | Apple MacOS, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits) | Dimensions (WxDxH) | 18.86 cm x 12.32 cm x 14.61 cm | Weight | 500 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: USBDUP15 |
General | |
Host Bus | USB 3.0 |
Storage Controller | |
Processor | ASM1053E / VIA812 |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s - SATA combo |
Connections | 1 x USB 3.0 - 9 pin USB Type B |
Miscellaneous | |
Cables Included | 1 x USB cable - external - 1 m , 3 x power cable - external |
Features | LED indicator, built-in cooling fan, built-in 2-port USB 3.0 hub, 1 USB 3.0 (powered), tested with up to 4TB 5400 RPM 3.5" hard drives, tested with up to 1TB 5400 RPM 2.5" hard drives |
Compliant Standards | Plug and Play, FCC, RoHS |
Power | |
Type | Power adapter |
Voltage Required | AC 120/230 V |
Software / System Requirements | |
OS Required | Apple MacOS, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 18.86 cm |
Depth | 12.32 cm |
Height | 14.61 cm |
Weight | 500 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
