Turn a 6 Gbps HDD or SSD into secure external storage with touchpad password entry. The S2510BU33PW USB 3.0 encrypted hard drive enclosure lets you to turn your 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an AES-encrypted external drive.
To ensure all of the data on your drive is protected from unauthorized access, the secure enclosure uses an Advanced Encryption Standard Algorithm (256-bit AES). Once your encryption is set, access to the content is only authorized through a customized PIN that you set and enter using the sleek built-in touchpad. The encryption is hardware based, eliminating the hassle of complicated software installation and configuration.
The hard drive enclosure ensures maximum performance, with support for USB 3.0 transfer speeds up to 5 Gbps. The enclosure also supports SATA III drives, ensuring you can still achieve high performance while accessing your SATA 6 Gbps SSD externally.
Product Description | StarTech.com Encrypted - storage enclosure - SATA 6Gb/s - USB 3.0 | Device Type | Storage enclosure - external | Bus Type | USB 3.0 | Colour | Black | Expansion Bays | 1 x internal - 2.5" | Hard Drive Form Factor Compatibility | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, solid state drive | Max Storage Devices Qty | 1 | Product Material | Plastic, steel | Dimensions (WxDxH) | 7.7 cm x 12.3 cm x 1.4 cm | Weight | 94 g | Manufacturer Warranty | 2-year warranty |
