With a funky textured outer material and slip proof lining, this nifty folio is a perfect fit for your Surface Pro 4 - protection, unlimited viewing angles and contemporary good looks. Now that's function with emotion.
Product Description | techair Folio - flip cover for tablet | Product Type | Flip cover for tablet | Screen Size Compatibility | 9.7" | Dimensions (WxDxH) | 24.5 cm x 2 cm x 17.3 cm | Weight | 240 g | Material | Twill polyester | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | Apple 9.7-inch iPad (5th generation, 6th generation) |
General | |
Width | 24.5 cm |
Depth | 2 cm |
Height | 17.3 cm |
Weight | 240 g |
Colour | Black |
Carrying Case | |
Type | Protective cover |
Recommended Use | For tablet |
Cover Type | Flip cover |
Open Type | Side |
Closure Type | Magnetic closure |
Inner Dimensions | 24 cm x 0.76 cm x 16.95 cm |
Cover Features | Stand function |
Manufacturer Warranty | |
Service & Support | Lifetime |
Compatibility Information | |
