The TomTom Touch is not just your average activity tracker. Track steps, sleep and heart rate, as well as your body composition. Body composition data allows you to measure your body fat and muscle mass percentage to better understand the impact of all your diet and workout activities over time.
Product Description | TomTom Touch activity tracker with strap - black - 4 MB | Product Type | Activity tracker | Tracking Data | Distance, time, calories burned, sleep activity, heart rate, steps taken, body composition | Connectivity | Bluetooth | Display | Monochrome 128 x 32 pixels | Storage | 4 MB | Band | Black - strap - size: S - changeable | Input | Touch screen | Fits Wrist with Circumference | 125-165 mm | Notifications | SMS | Features | Call alerts | Supported Host Device OS | iOS, Android | Battery Run Time | Up to 5 day(s) | Dimensions (WxDxH) | 19 mm x 11.5 mm | Weight | 10 g |
General | |
Supported Host Device OS | Android 4.3 (Jelly Bean) or later, iOS 8.0 or later |
Wearing Style | Wrist |
Clock Display | Yes |
Set Goals | Yes |
Sensors | Accelerometer, gyro sensor, heart rate |
Storage | |
Capacity | 4 MB |
Display | |
Type | Monochrome |
Resolution | 128 x 32 pixels |
Dimensions (WxH) | 5.58 mm x 22.38 mm |
Connectivity | |
Wireless Interface | Bluetooth 4.1 |
Input Device | |
Type | Touch sensitive screen |
Battery | |
Run Time (Up To) | 5 day(s) |
Band | |
Name | Strap |
Changeable | Yes |
Size | S |
Colour | Black |
Dimensions & Weight | |
Width | 19 mm |
Depth | 11.5 mm |
Weight | 10 g |
Miscellaneous | |
Protection | Splashproof |
Compliant Standards | IPX7 |
Included Accessories | Charging cable |
