Product Description | TP-Link AC500 Wireless Controller - network management device | Device Type | Network management device | Form Factor | Rack-mountable - 1U | Processor | 1 x MIPS64 1 GHz | RAM | 512 MB | Flash Memory | 32 MB | Ports Qty | 5 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet | Capacity | Manageable access points: 500 | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 22 cm x 4.4 cm |
General | |
Height (Rack Units) | 1U |
Width | 44 cm |
Depth | 22 cm |
Height | 4.4 cm |
Processor / Memory / Storage | |
Processors Installed | 1 x MIPS64 1 GHz |
RAM | 512 MB DDR3 SDRAM |
Networking | |
Form Factor | Rack-mountable |
Ports Qty | 5 |
Connectivity Technology | Wired |
Status Indicators | Power, system, link/activity |
Features | Load balancing, VLAN support, firmware upgradable, Wi-Fi Multimedia (WMM) support, DHCP server, Multiple SSID support, fanless, system log, SSID to VLAN mapping |
Encryption Algorithm | WPA, WPA2 |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.1x |
Expansion / Connectivity | |
Interfaces | 5 x 1000Base-T - RJ-45 , 1 x console - RJ-45 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
