The Pebble P-1 from Veho has a large 10,400mAh capacity with dual USB ports designed to enable charging of 2 devices simultaneously.
The fast 2.1A charging output has been designed to charge tablets, smartphones, Sat Nav’s, GPS’s trackers and other portable USB devices fast and efficiently.
The Pebble P-1 allows you to use your own charging cable to charge up your devices’ and is capable of charging the popular smartphones such as the iPhone 7 up to 5 times and the Samsung Galaxy S8 up to 3 times.
With a USB-C input charging port, the Pebble P-1 is compatible and future proof for new USB-C devices and cables, so you won’t have to update your power bank when you update your smartphone, tablet or portable device.
The Pebble P-1 incorporates Pebble stylish ergonomic design, which has been popular with power bank users. The power bank features a smooth matte black, Tacton rubber touch finish and a digital LED display indicator giving the exact percentage available.
Designed in the UK, the Pebble P-1 is packed with superior quality lithium-ion battery cells, ensuring that you get the true mAh rating and conform to all safety marks and regulations such as CE, RoHS and EMC.
The Pebble P-1 comes with micro-USB to USB-A charging cable, a protective carry pouch and multi-lingual user manual.
Key Features
Box Contents
Product Description | Veho Pebble P-1 power bank - USB | Product Type | Power bank | Dimensions (WxDxH) | 11.5 cm x 7.8 cm x 2.55 cm | Weight | 260 g | Output Connector Type | USB | Voltage Required | 5 V | Voltage Provided | 5 V | Max Electric Current | 2.1 A | Battery | 10400 mAh | Cables | Micro-USB to USB cable |
General | |
Designed For | Tablet, mobile phone |
Width | 11.5 cm |
Depth | 7.8 cm |
Height | 2.55 cm |
Weight | 260 g |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B, 24 pin USB-C |
Output connectors | 4 pin USB Type A |
Features | LED indicator |
Battery | |
Capacity | 10400 mAh |
Features | On/off button |
Miscellaneous | |
Included Accessories | Carrying pouch |
Cables Included | Micro-USB to USB cable |
Compliant Standards | EMC, RoHS |
