We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Significant design advances in WD's hard drive technology, combine optimized AV performance with best-in-class power consumption and thermally optimized operation enabling unparalleled cost of ownership for manufacturers of digital video recording devices.
Product Description | WD AV WD5000AURX - hard drive - 500 GB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 500 GB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 5400 rpm | Features | Advanced Format technology, 24x7 availability | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 500 GB |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Reliability | |
24x7 Operation | Yes |
Expansion & Connectivity | |
Interfaces | SATA 6 Gb/s |
Compatible Bay | 3.5" |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
