Belkin DisplayPort cables bring an all-digital, high-performance cable standard to life. DisplayPort cables provide the ideal digital display interface standard for maximum high-definition performance, all in one cable. This top-of-the-line technology delivers extreme refresh rates, intense color depths, and high resolution for all your computing display needs. With its compact size, Belkin DisplayPort cables will be the only high-definition, all-digital audio video cable a user will need for any DisplayPort-enabled digital computing device.
Product Description | Belkin 10ft DisplayPort 1.2 Cable with Latches, M/M, 4k - DisplayPort cable - 3 m | Type | DisplayPort cable | Length | 3 m | Connector | DisplayPort - male | Connector (Second End) | DisplayPort - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: F1DN104W-3 |
General | |
Length | 3 m |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 20 pin DisplayPort - male |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
