Extend your wi-fi signal even further with any broadband provider
Tri-band technology pushes faster, stronger wi-fi to every corner of your home
The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time.
Adding an extra disc is perfect for larger homes, those with thick walls or when you need wi-fi in your garage or garden. A maximum of 6 discs can be supported on a network. This disc only works with other Whole Home Premium discs.
Now you can have multiple users streaming TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
Premium Whole Home Wi-Fi coverage
Standard router coverage
Set schedules to control wi-fi access for individual users or groups of devices to make sure bedtime is free from screen time.
Want to get everyone down for dinner? Temporarily pause the internet with one tap. Only want to pause it for the kids? It’s easy to set schedules so individual users or devices get some time offline.
Create a separate network for guests and keep your home network secure. It’s easy to share access details via the app, see which devices are connected and block any you don’t recognise.
Product Description | BT Premium Whole Home Wi-Fi Add-on disc - radio access point | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11ax, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Manufacturer Warranty | 3-year warranty |
General | |
Networking | |
Connectivity Technology | Tri-band Wireless technology |
Data Link Protocol | IEEE 802.11ax 5GHz, 802.11a/n/ac 5GHz, 802.11b/g/n 2.4GHz |
Status Indicators | WPS, starting, connection status |
Features | Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network |
Encryption Algorithm | AES, TKIP, WPA, WPA2, WPS |
Compliant Standards | IEEE 802.11ax, IEEE 802.11ac, IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v |
Aerial | |
Antenna | Internal |
Antenna Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 (WAN) |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | External power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% |
