The BT Mini Connectors allow you to connect your BT TV box to your BT Hub.
Product Description | BT Mini Connector Kit - bridge - wall-pluggable | Device Type | Bridge | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
General | |
Connectivity Technology | Wired |
Compliant Standards | R&TTE Directive 1999/5/EC |
Status Indicators | Power, LAN, data |
Expansion / Connectivity | |
Interfaces | LAN: 1 x power , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 5.3 Watt |
Miscellaneous | |
Cables Included | 2 x network cable |
The following resources are available for the BT Mini Connector Kit
