This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a DisplayPort input. This adapter converter carries a digital audio/video signal and supports up to a 4k resolution and meets the requirements of high performance applications.
Product Description | C2G 15cm Mini DisplayPort to DisplayPort Adapter Converter 4K UHD - Mini DP Male to DP Female - White - DisplayPort cable - 15 cm | Type | DisplayPort cable | Length | 15 cm | Connector | Mini DisplayPort - male | Connector (Second End) | DisplayPort - female | Colour | White | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 15 cm |
Colour | White |
Connectivity | |
Connector (Second End) | 20 pin DisplayPort - female |
Miscellaneous | |
Compliant Standards | DisplayPort 1.2 |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
