IEEE 1394b FireWire cables by C2G are the latest in FireWire technology. IEEE 1394b or FireWire 800 provides transfer speeds up to a blazing 800 Mbps! This is twice the speed of the original 1394 standard. 1394b is a must-have for transporting and networking multiple types of digital data between users and systems. Digital Video camcorders, scanners, printers, video conferencing cameras and fixed-disk drives can all share a common bus connection to one PC, as well as to each other. With Windows Me or Apple's FireWire target disk mode you can use an IEEE-1394b cable to connect two computers together to allow for file sharing.
Product Description | C2G - IEEE 1394 cable - FireWire 800 to FireWire 800 - 1 m | Type | IEEE 1394 cable | Technology | Shielded | Features | Molded | Length | 1 m | Connector | 9 pin FireWire 800 - male | Connector (Second End) | 9 pin FireWire 800 - male | Compliant Standards | IEEE 1394b |
General | |
Features | Molded |
Length | 1 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | IEEE 1394b, Plug and Play, RoHS |
