When you need just a little more distance, this cable will extend the reach of your USB A/B cable. Foil and braid shielding reduce EMI/RFI interference and twisted pair construction helps reduce crosstalk for a high speed, error-free data transfer. USB 2.0 compatible. PC and Mac compatible. Please Note: Not for use beyond a total extended single length of 5 metres. For longer lengths or high-powered devices, please use product 81655, 5m USB A Male to A Female Active Extension Cable.
Product Description | C2G USB Extension Cable - USB extension cable - USB to USB - 1 m | Type | USB extension cable | Technology | Double shielded twisted pair | Length | 1 m | Connector | 4 pin USB Type A - female | Connector (Second End) | 4 pin USB Type A - male |
General | |
Length | 1 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
