We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a DVI-D input. This adapter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description | C2G DisplayPort to DVI-D Adapter Converter - Single Link DVI-D Video Adapter M/F - Black - video adapter - 20 cm | Type | Video adapter | Features | Latched | Length | 20 cm | Connector | DisplayPort - male | Connector (Second End) | DVI-D - female | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 20 cm |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 18+1 pin digital DVI (Single-Link) - female |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
